is it me, i just posted & then found 7 or 8 more replies.
D_Hailsham";p="962313 said:Apollo Fanfare! Got one myself. They are fairly fussy on the setting of the bypass valve. It should be adjusted so the flow/return temperature difference at the boiler is 9°C. The drop across each radiator should still be 11°C.
Would a bypass valve as you suggest satisfy the "fussy" boiler?
The bypass should be the first connection after the pump on the flow and the last connection on the return pipe.
