Interesting suggestion, do you have any examples of this ? I've never really used a blow before.Garden blower.
You can devise a custom built attachment to use vacuum cleaner accessories.
A very good find! How good is it for pushing gunk out ? Will it leave remnants or does it remove everything ? I'm just wondering if the tank is full how easily is would dispose of it's contents and with what force.A lot of shop type vacs can be used to blow as well. Don't expect it to be the same as a compressed air supply though!
I have this for example, and it's quite decent for the price:
(You reconnect the hose to the waste air outlet)
"vacuum cleaners with reversible air flow"
I could imagine some disastrous accidents with this - the bags full of dust and dog hairs, you just need to suck up a few crumbs spilt accidentally in an otherwise pristine living/drawing room, the suck/blow switch gets accidentally toggled to blow ...... the once full bag of muck is now empty!
ahh, thats good - I had momentarily worried of a disagreeable neighbour situation and thoughts on their letter box.The blow, is simply the exhaust from the vacuum's suck, but with a means to connect a hose. It goes through the usual filter system, before being expelled, so you don't get your dust back.
As has been said by everyone else, the 'blow' isn't intended to empty the dust container of what has already been sucked up.A very good find! How good is it for pushing gunk out ? Will it leave remnants or does it remove everything ? I'm just wondering if the tank is full how easily is would dispose of it's contents and with what force.
The filter is however removable. It could still create a bit of a mess - this may be an experiment for tomorrow!The blow, is simply the exhaust from the vacuum's suck, but with a means to connect a hose. It goes through the usual filter system, before being expelled, so you don't get your dust back.
my dad in the 60s had i think it was an electrolux vacuum and the exhaust had the same fixing as suction end and it had a jar spray nozzle to spray paint and he did use it
You can still buy a brand new traditional cylinder vac if you want to...link cylinder vacmy dad in the 60s had i think it was an electrolux vacuum and the exhaust had the same fixing as suction end and it had a jar spray nozzle to spray paint and he did use it
