Rewired in 1986, but with a spade fuse consumer unit?
3 Jun 2007
Lancashire
Hi all,
I'm thinking of buying a house, and the HIP says it was completely rewired in 1986, but some of the wiring looks like bad DIY and I've got my doubts about when it was done.
The consumer unit is cartridge/spade type rather than having circuit breakers - does that sound like 1986, or did CBs come in later?
Cheers
Liam
Nothing wrong with cartridge fuses as long as the circuits are compliant with them. Just a little inconvienient if you are unlucky enough to blow one...
Can you get a photo of the installation and post it here? It's hard to make any sort of judgement without seeing it.
Cartridge fuses fitted in 1986 would be very likely.
Although circuit breakers were available then, they certainly weren't standard for new installations.
Even if the information in the HIP is correct, all kinds of alterations and additions could have been made since then by dozens of different people.
The 'rewire' could have been done to a very high standard, exceptionally poorly or anything in between.
All of the information in a HIP should be ignored, since the majority of it is completely unproveable and therefore worthless.
Thanks everyone.
I suspect it is a rewire with DIY "enhancements" - like the 6mm T&E nailed to the fence going to the garage and "protected" with plastic cover that you use under plaster!
