My approved application mentions a ridge height of 6339mm above ground. As the ground is quite inclined and uneven around the house, is there a standard method of determining the ridge height, for example when the neighbours complain ?
How are the neighbours going to complain if your plan has been approved?My approved application mentions a ridge height of 6339mm above ground. As the ground is quite inclined and uneven around the house, is there a standard method of determining the ridge height, for example when the neighbours complain ?
it is too vague -its impossible to be specific about a height above a datum when the datum is not clearly determined.This is something I've encountered on numerous occasions, usually when enforcement has asked me to measure it on their behalf, my first question is always from which point and even to ask do you mean internal or external level, existing original level(s) or raised level. I can't remeber how many times that I've told them the condition is to vague. One authority did change there wording to a fixed level to be marked and agreed on site.
To be fair my last authority did change the wording on my suggestion.it is too vague -its impossible to be specific about a height above a datum when the datum is not clearly determined.
If a surveyor did a measured survey, the levels would be marked at various points on the site -all taken from a datum.
