I appear to have a small leak from the oil pump. Looks to be coming from the joint between the pump cover & main body. But that's only based on where the oil lands on a piece of kitchen roll placed under the pump. I can't actually see it as it's both inaccessible & just a weep. So could potentially be leaking elsewhere & gravity taking it to the lowest point.
I've tried nipping the four allen screws a touch tighter but to no avail. Google seems to suggest that there's a filter & gasket in there so I guess I need to replace the gasket? Can someone please point me to the correct parts?
As an aside, the leak started immediately (well next day) after the latest delivery. Just coincidence or could something be wrong with the oil? Having collected some of the leaked oil it is yellow, where all the online videos I've seen when researching a different issue on my Mother's boiler show it as red. No idea if that's relevant?
The delivery was also a top-up from half-full on a 1200 litre tank. So at worst would have been a 50:50 mix with the old oil that wasn't leaking. So I'm tending towards co-incidence.
