Ring extension load
3 Jan 2015
London
Hi, what is the safe wattage capacity on a 2.5mm cable as extension (1.5m) off a ring? (I believe this is called a spur?)
Is it enough to power a double socket for wash machine and dryer?
1 spur = 1 double socket. Not more than that.
People could then plug in whatever appliances they wanted into that double socket.
NO. Nor is a double socket safe for that purpose. With a double you can't put a full 13 amps on both sides at the same time.
That may be, but there is nothing to stop people plugging in whatever appliances they want into any double socket anywhere in their home at any time they like.
A washing machine and tumble dryer are not 'full 13A' items anyway. The washer will use a tiny fraction of that for the majority of the time it is in use.
4500/240=18.75. But it will be a bit more as the motors will not be unity power factor.
That's assuming the appliances are rated at 240v, they could be rated at 230v. Also don't some manufactures specify their own current rating that their double sockets can take what is different and often higher than the 13A as specified in BS7671? Although one should never assume that a double socket can take more than 13A in total to be on the safe side and in compliance with BS7671.
What is the wattage?
The power consumption of an appliance.
I can find wattage 583 KW/H anum and 4.97 kw/H per cycle.
That's not wattage.
You would need to know how long the machine was on to work it out.
Like your car does 150mph; how far have you driven?
When working out wattage for cable capacity dont I need wattage per second?
Wattage is wattage. 1000W for an hour (NOT per hour) is 1000Wh (1kWh)
You need to know the current for cable selection - Wattage÷Voltage.
4500/230=19.56A. But it gets worse as most likely his actual voltage is 240 so 19.56*240/230=20.4 amps.
True but not relevant as that will be allowed for in the Current Carrying Capacity given for cables.
Hence why we use 230V for calculations.
The current carrying capacity was decided before 230v was used in calculations.
SO is it safe to run the washing machine and dryer from the spur double socket? Cable goes through insulated stud wall. CAn it cause a fire or will the fuse cut it out if there is a problem?
