We had an issue with our gate intercom (Videx VR4K-1 kit) where the cables between gate and intercom handset in the house (which route under ground) have degraded over time (old system) and so the system needed replaced. The cables were deemed to be no longer working. Unfortunately, the gate repair company have removed all the previous wiring for the intercom (including the connections from the Videx power supply to the Videx intercom and to the gate Beninca BRAINY24 control panel) as the intercom was deemed useless.
Got a quote for a new GSM system but looked into Ring as an alternative and have gone ahead and bought a Ring Doorbell 4 and the Ring Intercom kit.
As we now have no working wiring between gate and house, I plan to put the Ring Intercom in the gate box outside (covered by wifi).
Any ideas whether the Ring Intercom can connect direct to the Beninca BRAINY24 gate control board, just to trigger the open function . My thought is to use use "Open" (connector #21) and "COM" (connector #25)? If this is the case, any programming required?
Or... Do I need the Videx ART.520M power supply reconnected, along with the Videx ART.136 intercom refitted, and the Ring Intercom then connects to the intercom?
From what I can tell, it just needs 2 connections; Ground and Door Open.
Thanks!
Thanks!
