The socket & see 36 tester will show if the earth loop impedance is better that 1.8 Ω, and 92 Ω one assumes the 1.8 Ω for TN and 92 Ω for TT, it is not really low enough for a British ring final which should be better than 1.36 Ω but for a cheap plug in tester it is about as good as it gets, it also uses your body as a reference to check of incorrect pins it seems. However the socket & see 22 is rather a cheap version and does not test the loop impedance or RCD at even the most basic level. The 36 uses 7 mA line - earth which should not trip an RCD to do loop test and 30 mA for RCD test but is does not measure time, but should identify a fault RCD or one frozen due to DC.
At around £50 the 36 is far more expensive to the 22, but far cheaper than the socket & see PDL234 and even that one does not give an actual reading in ohms. The Martindale EZ165 seems a little cheaper to the socket & see 36 tester, also the socket & see 34 tester does loop. And the Kewtech Loopcheck 107.
The Martindale EZ2500E-Ze seems to be the cheapest true earth loop impedance tester at around £130 at a quick hunt, with a true loop tester you may be able without removing the sockets to detect the area of the fault, but the go/no go testers do show when there is a fault in most cases, but not good enough to help trace where or completed the paperwork required. Both the loop impedance tester and RCD testers are expensive bits of kit.
Oddly the insulation tester using 500 volt I have picked up new for £35, these are in comparison cheap.
