Ok here is a problem regarding rising damp on a wall….simply enough but a bit awkward to resolve for the following reasons………….
The damp is on a holiday home abroad so my time is restricted as only there 3 weeks in the year, and I have other `jobs` to do when there so time limited.
The building is only single skin as they are built for summer weather (9 months of year)
They do not have a damp proof course.
If I do nothing then it takes about an hour to scrape the wall and repaint once a year, that’s my current solution to the problem.
Picture below…
A= The wall where the rising damp is rises about 2 feet up the wall internally
B= This is (I believe) the main foundations which is a concrete base on which the house
is built and leaves a sort of pathway about 3 feet wide around the building (concrete and not tiled), this is
where I believe the source of the rising damp is originating from.
You will note that the tiles on section A are not `grouted`, I am doing a section each time I visit and this might go part way to solving the problem as it will give an extra skin.
Anyone got any ideas that might give a quick fix or help improve if not cure the problem. Please bear in mind my time out there is limited and certain products may not be easily or readily available.
thanks
Picture below…
thanks
