Ro tubing to american fridge?
8 Jan 2006
Northern Ireland
hi im getting an american fridge with filtered water/ice making facility.
im looking to connect my ro filtered water (50gallon 4 stage ro with pump) to it.
The manual says i need a straight appliance tap or 15mm x 3/4 BSP.
What do i need to connect my ro system to the fridge?
(ro tubing to make it appear as straight appliance tap for the fridge water pipe to screw in?
I can get a convertor for ro system to fit an outside tap*, can you get such a thing that has threads on either side so to screw in the outside tape connection and on the other end to screw in the fridge connection?
*John Guest 3/4 BSP Female to 1/4 Push Fit Fitting
Nipple. ;)
If you want unequal sizes, then bush one end of the nipple. ;)
Seriously, these are the proper terms. :shock:
Quite so. And I never start a job without my trusty pair of testacles.
I think you hit the t & r key together, did you mean to type rusty. :lol:
just an update/info for anyone else looking to do the same.
You can get a conversion pack from the manufacturer/place where you bought the fridge. In america this is the type of connector used when connection water to big fridge.
