- Joined
- 11 Jan 2009
- Messages
- 1,101
- Reaction score
- 6
- Country
Hi
Am having old gravity boiler replaced by Combi (Worcester Greenstar 30 CDI).
I was originally told the work would take 3.5-4 days and they are 2 days in. The thing is er indoors is unhappy on a number of fronts and I must confess that our kitchen now looks like a war zone and something out of Rogue Traders.
Gist is that we were originally advised that best (probably only) place for Combi was in kitchen where the old one was:
• We don’t have outbuildings or garage
• didn’t have any empty cupboards in the kitchen
• decided that putting it in the airing cupboard would require drain and pressure hoses going through the roof etc and would be too expensive
• Didn’t fancy having it in the loft
Having ripped out the old one yesterday along with the hot water cylinder and cistern in the loft they tell me today that they can’t do plan A cos the boiler would be too close to the hob (needs to be minimum of 750mm and would have only been 585mm). They then suggest removing one of our adjacent overhead cupboards to accommodate the boiler and somehow replace the cupboard on the other side of the boiler.
Why they didn’t realise this before baffles me but I’ll go on. At the end of day 2 we have:
• Massive square hole where they removed the old vent on the wall
• Two smaller holes now accommodating the discharge hose/pipes
• Broken external brickwork where they drilled the holes
• About 15 tiles removed
• The double socket underneath the boiler now almost hanging cos it’s resting on one tile and bare plasterboard.
All in all and making allowances for the fact that they haven’t finished and we aint paid a penny does this sound like Plumbers from Hell? (they are an established firm recommended by the guy who’s going to do our bathroom and are Corgi registered)
Specifically:
1. Does the location sound OK? (not directly over but near the gas hob)
2. Should they be able to retile behind the 5 copper pipes?
3. Will they be able to spur into the power supply to the double socket without too much damage?
4. Is it easy for them to brick up the hole where the old vent was?
5. Can they make good where they damaged the bricks when drilling?
6. I noticed that the bore holes for the two pipes (one plastic and one copper) seem to be a fair bit bigger than the pipe diameter. Should they be able to rectify this to stop water and damp coming in?
7. Is repositioning the overhead cupboard above the hob a serious fire hazard?
Many thanks for your time. Realise that I’ve twittered on but very tired and fed up at the moment.
Specifically:
