A month ago, my door and window frames needed repainting. Three parts of the frames had started to rot (2 bad-ish, 1 not so bad spot). In these places, I dug out the rot and some surrounding wood, used a lot of Ronseal wet rot wood hardener, gave it ages to dry, gave it a rub down with a metal scourer (the box said to use a wire brush but I didn't have one - this is the only instruction I think I didn't follow; I had been following the instructions on the packs and on Ronseal's website very carefully), used the 2 part wood filler and, again, gave it ages to dry. In the morning it seemed absolutely solid. I then sanded all the door and window frames with 60 then 120 grit, and painted with Ronseal 10 year exterior wood paint. It all looked very good for the next week or so that I inspected it.
One month later, I have noticed that in all three places the filler appears to be pulling away from the frames. On one window sill, it seems to be pulling the wood up with it - making a really long crack. I would like to get it sorted before the winter, but I don't know what to do - I used expensive stuff that I thought was the gold standard for this kind of repair but, as it failed in all 3 places I used it, it doesn't feel wise to do the same again (with a wire brush this time!) The paint is all fine in the places I didn't use any filler, so it's something to do with the hardener or filler. When I pull off the cracked parts it's a thick layer of filler (all of the filler comes off) plus a bit of wood.
I am out of ideas, and would really appreciate some help. I have no idea why this might've happened. Can anybody help? Thanks
