Roofer has joined marley ludlow tiles to my neighbours redland 49 is this o.k
18 Mar 2026
My Roofer has joined my Marley Ludlow tiles to my neighbours redland 49 without a bonding gutter says he has checked and this is o.k
Thanks for reply will just keep an eye on things as solicitor advised and if it goes wrong well its off to court
OP,
Unless you are bonding like for like then its best practice to use a bonding gutter.
The Ludlow & the Redlands might appear to have bonded but give it a bit of time and the join will probably leak.
FWIW: there's more to bonding a roof than just installing a bonding gutter.
Looking at lap layout/dims they seem just about compatible and may cause less problems that fitting a bonding gutter and more aesthetically pleasing?
OP,
The Ludlow & the Redland are not compatible:
Their dimensions are different.
Plus the Redland has a camber.
Joining roof covers on the same plane requires taking care and time to do a correct job while giving attention to details.
Or else you might be clambering on the roof doing remedial repairs for many years to come plus the irregular join maybe red flagged by a future mortgage surveyor.
I would do my own check with Marley's technical chaps and unless they confirm it's fine get your man back to the job right.
