Roofing in rain
30 Nov 2010
Berkshire
Hello,
We're having an extension built and the roof tiling is planned for tomorrow. It's due to rain heavily over the coming days and next and I'm concerned this will cause problems down the road. The roof has been felted for the past 4 weeks and has been regularly drenched, but I'm told by the builder this is not a problem, despite the walls apparently getting wet at the top, inside and out.
I'd be interested to know if roofing in the wet weather will cause me problems in future.
Picture included of the current state of the roof when it last rained
Many thanks
no reason to panic, it wont rain forever and you have a decent underlay one of the best imho.
Fascia looks a bit skinny is it cappit? and don't forget underlay support trays
Thanks for the reply. Just to check, it's ok to lay the tiles while raining/battens and underlay wet? There won't be time to dry anything out.
The roofer has wrongly stopped the felt behind the fascia - its been cut too short.
Felt should be left long to flap over the fascia, and only be cut when the gutters are fixed in place.
As above - a felt support tray/plastic eaves tray and long rippings of 1m x ? felt to back up the in-place felt will solve your problem.
The first batten will have to be lifted for sliding the ripping in under the in-place felt.
Just saying: its not sound to work on any roof in wet weather - even though you are working from a scaff.
Has the cavity insulation been soaked?
Thanks for response. No insulation in place yet. It's been like this for well over a month now apparently waiting for the tiles, with basically nothing happening inside or out..
When you say long rippings of 1m felt do you mean an additional layer of felt under the existing felt layer (and under the first batten)?
Yes.
Hope you understand I'm talking about the cavity insulation in the wall - surely its in by now?
Underlay does not need to hang into the gutter once an underlay support is in place . It'll only rot off in no time.
The tile in the distance looks like either a sandtoft 2020 or Cassius both clay and good.
Every thing in your image looks fine apart from the fascia which looks like a cappit without a back board .. again guessing from the image .
Yes.
Oh right yes, sorry. The insulation was wet although I had a feel about and it didn't feel soaking and I challenged the builder on this but was told it would be fine as it would dry. I did ask, early on, why the roof wasn't tarped, but was told it wasn't needed. Is this a concern?
Thank you. Is this type of fascia inappropriate?
The weather will have zero effect on your roof..it will dry out when it is tiled..roofs are stripped, felted and tiled in the rain its par for the course.
tarps can make things worse, they crease up and water pools and then runs in through holes or tears in the tarp
A tarp will also keep a roof roof constantly damp, its better to let the wind get to it.
