room extention
7 Jul 2008
Essex
I wish to have a dormer window put onto the front bedroom on my house however I have been informed that you are no longer able to have dormers built at the front of a property is this true?
No its not true
And planning permission is not always required either. It depends on specific circumstances
edit:
see post below re: roofs fronting a highway
Didn't know that woody, I've thought if the roof size is altered, I thought planning premission kicked in(?)
If you planning modifications that affects the front aspect of your property, it's always wise to enquire if you need permission. I wanted to change 2 flat roof windows to dormers & install a 3rd dormer in an extension & I was told I would need PP even without the 3rd window extension!
Yes, sorry .... just to clarify
The key thing with planning and roof work is that if the work is higher than the plane of any existing roof slope (which a dormer will be) and if that section of roof fronts any highway, then permission is required.
The OP should check with local planning policy, as some LA's have some bizarre reasons for circumstances when dormers may or may not be acceptable
