- Joined
- 27 Jan 2008
- Messages
- 27,570
- Reaction score
- 3,332
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
In the summer the hall TRV and the wall thermostat showed the same temperature, so reasonably sure they are both reasonably accurate, but today TRV shows 15°C and wall thermostat shows 18°C and this is quite common.
Living room two TRV's one shows 15°C the other 17°C they are at 90° to each other and one protected from draft by furniture, that one shows lowest. Once heating has been running then the living room will swap which shows lowest.
Dinning room lowest at 14°C with target at 17°C.
The wall thermostat in the hall has only just reached 18°C (6:45 am) after turning down from 20.5°C at 10 pm. It reports at -1°C outside, away from radiators in living room 14.2°C heating due to turn up at 7:15 am and once it has been running for a little time the temperatures do even out a bit, and not worried as bedroom still at 18.2°C
But the hall is the problem area, as it is so slow to cool where the wall thermostat is, which is around central to house, and where people in the house are most likely to pass so trigger the occupancy sensor. It is also between the doors for 4 rooms so during the day when doors open and people walking around it gets a reasonable average of all entrance floor rooms.
At the moment the hall TRV is actually set lower than wall thermostat as it is always recording a lower temperature, and it works well, however as summer approaches then the difference will reduce.
I wonder if you can get a TRV head with a remote sensor so it can be placed higher up so it reads same temperature as wall thermostat so no adjust is required as summer approaches?
