Rothenberger Super fire 2 blow torch problem
19 May 2007
No gas is coming out of the torch when I press the button. It was working fine until the gas ran out of the previous bottle and won't work with the new bottle and it has the same fitting. When I press the valve in the bottle it releases gas at pressure. Anyone else had a problem like this?
Not a problem I’ve had. Have you definitely opened the knob?
Have you had snots of solder drop into the nozzle? Usually need another torch to heat the blocked one and melt the snots back out.
