routing out a 35mm deep and 12mm wide rebate in the bottom of a hardwood door
I do have an old Dewalt/Elu plunge biscuit joiner but the depth of cut wouldn't be enough.
Get a Festool. You know you want to :giggle:
Does your saw have a decent side fence? Not as easy as a router, but ...
Or burn it all out with a 9" masonry angle grinder, use No Nails to fix the thing and fill the gaps, job's a good'un.
Americans use a wobble blade in a circular saw. I've never seen it done here.
You could use a plough plane or combination plane. I imagine you'd do the two saw cuts first.
I got a morticing jig recently, but it is not intended for such a long cut.
I believe that wobble blades in the UK are illegal. I think it is because the blade guard would have to be removed, additionally the spindle would not be long enough to accommodate both blades.
I was under the impression that the direction of "cut" doesn't matter in a rebated channel?
it will tend to be neutral as both blades are cutting evenly but once you introduce movement the blade in direction off travel will take more load and once the cutter has nothing to eat into at the back it will stop counteracting the front blades attempt to move sideways
mind you iff your anything like me you will be holding the router so tightly and pulling hard against the fence that unless you have overloaded the cutter by 4 or 5 times to get it done in one it will have little chance off deviating and for what its worth i woudnt go above 9.5mm as 50% more than you should at half the shank 6.35mm cut
Yup.
The floor is tiled and about 6mm lower than the threshold. With the mat in place the gap to the top edge of the threshold is only about 2-3mm.
A brush would be a PITA.
I put a wooden batten, stained to match the door and the sill, on the floor for the draught strip to press against.
