Good points there.
Without storage heaters I just could not make E7 pay for the higher day rates and higher standing charge. Never understood the need to pre warm the house before you came home - you are heating an empty house. Where is the eco sense in that.
Today we have Drayton Wiser, which works out how far ahead of time, we need to start heating a room, so it is up to temperature at the required time. Back then, I had to guess how long it would take.
We left our house to look after mother, the heating was left on a low heat setting to stop any pipes freezing, but lifting the house from near enough ambient temperature of around 12ºC to 20ºC is not that fast, main room had a Myson fan assisted radiator 3 kW, a standard radiator 4 kW and a gas fire 4.5 kW but still nearly ½ hour to reheat the room. Normally, the room would have only cooled to around 16ºC by 4 pm, so reheated much faster.
This house is much slower to reheat, but also slower to cool, and I have needed to alter how the heating is controlled, due to hall cooling slower than the living room, so found we needed three units which could turn on the central heating, to allow for changes mainly down to internal doors left open or closed.
But both with gas and oil, we heat rooms only when required, and only just warm enough, with 14 electronic programmable TRV heads, and this is where the storage radiator fails, you can't decide, Oh, the family have just said they are coming around, we will need dinning room, and spare bedroom heating, let's switch it on now, you need to plan at least a day ahead, and so end up heating rooms at times when not required.
The larger the radiators (in output) and the larger the boiler (in output) the faster one can heat rooms and home, but in the main the boiler does not need to be that big, as one can heat rooms in the sequence in what they will be used.
But all of this goes out of the window with storage radiators, Although off-peak central heating does not need to use storage radiators, I saw a set of council houses in North Wales where there was a hot room and blown air fed other rooms from it, and told they could turn off the input and the heat would remain for a week, but this is unusual. And the house was designed to use this system from the word go, central heating was not an afterthought.
But once anyone realises using heaters as and when required, rather than just in case needed latter, works out cheaper, they will not return to Economy 7.
