Run central heating without heating
23 Sep 2009
Oxford
I was wondering if it is possible to run the central heating pump without turning the heating on.
The reason being I have just put some cleaner in my sealed system for maintenance. I like it to run around the system but would rather not turn on the heating as it is already too hot outside.
The boiler is vaillant 831 in sealed system.
Turn the gas off? Failing that, can you turn the boiler temperature down to as low as it will go and open some windows?
Press the reset button then immediately press and hold +
You'll get a flashing dot followed by P.0
Press i
The pump should now run for about 10 minutes
Run it for a few minutes.It is not going to heat your house that quick..Turning the gas off will lock the boiler out after a few ignition attempts.
Most cleansers will work a lot better with the system hot, I would not flush cold
