Running conduit for Virgin and BT cables
22 Oct 2015
Hey there
So I'm currently planning out our new extension, which will include an integrated garage.
As part of the garage, I'm planning on relocating some computer gear into a dedicated rack. I also want to relocate our existing BT and Virgin business services to the same location.
As I'm going to be digging up the driveway anyway, I'm thinking it would make sense to run conduit to enable the new cables to be pulled in easily and to where I want them without having to clip to the side of the house or drill holes...
Has anyone done anything similar? Any pointers on how best to proceed?
Thanks in advance.
Gavin
30 Dec 2018
Good idea, I don't like cables strung along walls. If you run conduit, then it would need to be reasonably straight/ no elbows or bends unless some access were left at the bends. A draw wire will need to be left in there as well. I have no suggestions on size needed, but 25mm conduit should be adequate.
2 Jul 2020
It is unlikely VM will agree to move the termination boxes without significant cost, as the new 54mm duct would need to come from the 96mm under the highway or footpath.
It will probably be simpler for you to run cable internally from the existing termination point to the location where you would like your equipment; all cables in the house are meant to be terminated there for VM anyways.
VM spec is:
RG6/RG59 Coaxial Cable
Triple shielded white Coaxial cable, "supplied by Virgin Media" but its made by Amphenol.
Broadband Solutions.
27 Apr 2008
The bigger size you can use the greater your ability to use it better in future.
ISTR VM use a pipe that looks like 50mm to me.
Leave a drawstring in it.
