I have a custom bade stainless steel splash- back been in position for about 23 years. Its stainless steel contact glued onto OSB. It is coming away from the OSB in a section. from under the wall unit to to work top I need to somehow get some glue down from the top as I have a 5mm gap between the top of the stainless and the underneath of the wall unit.
I need a glue thin enough to be syringed through a thin pipe or thin tube bent at 90 degrees. Thin so it can run down to the worktop.
I was thinking a fibreglass resin but know nothing abut the stuff - any other ideas.
