- Joined
- 5 Nov 2010
- Messages
- 409
- Reaction score
- 3
- Country
As the subject line says I would like to screw a M10 hook into a 30mm thick joist in the loft.
I want to screw 2 hooks into separate joists to hang a bar for pull-ups. If I was screwing them into the first floor joists then I know that would be fine as the joist are thicker.
I believe the weight isn’t the problem but just wondering if the thickness of the screw would compromise a joist of this thickness since it leaves 10mm on either side?
Is there a general rule to follow perhaps?
Thanks very much.
Thanks very much.
