safe zone in wall corner
6 Nov 2008
Durham
looking at the wiki, electric able e.g 2.5m should not be run within 150mm of the angle forms of walls i.e corners as it's not a safe zone. Why is that? I take it it's better to not run it in this area or bury it under 50mm of surface.
The reason I ask is its easier to do it within this area but I want to keep the job right.
Also when linking two double sockets next to each other or indeed sockets on the same wall is it best practice to run the able directly between the middle of the sockets as opposed to them being chased underneath and running into the bottom of the sockets?
Thanks ....
Within 150mm of a corner of a wall does count as a safe zone according to BS7671, but it should only ever really be used as an absoloute last resort.
You should read the words in that article, not just look at the pictures and guess what they mean. :wink:
The problem with horizontal chases is that you're limited on the depth as they can easily weaken walls. They should not be more than ¹/6 the thickness of the wall or leaf,
