looking at the wiki, electric able e.g 2.5m should not be run within 150mm of the angle forms of walls i.e corners as it's not a safe zone. Why is that? I take it it's better to not run it in this area or bury it under 50mm of surface.
The reason I ask is its easier to do it within this area but I want to keep the job right.
Also when linking two double sockets next to each other or indeed sockets on the same wall is it best practice to run the able directly between the middle of the sockets as opposed to them being chased underneath and running into the bottom of the sockets?
Thanks ....
Thanks ....
