Hello all,
having read the Wiki entry on safe zones, I am not sure what to do in the following situtation.
I am putting in a spur from a ringed socket in one room, and the cable need to go along the wall to a corner, round the internal corner for about 30-45cm, then through the wall to the room where I need the new socket. It then needs to go up to get the socket to the appropriate height.
My question is this. In the first room, the horizontal safe zone from the existing socket goes to the corner, OK, but does it extend round the corner? If not how should I deal with the length I need around the corner before I get to the point where I go right through to the other room?
Would a better idea be to get to the corner, do the up bit in the 15cm zone, also, go through the wall, then use the horizontal safe zone from the new socket in the second room for the channel to the corner ?
Although the above descriptions make perfect sense in my head, its just possible (!) they are not detailed enough. I could draw a piccy if that would help.
James
James
