Salamander ESP 100 twin problems
25 Feb 2007
Blackpool
Hi
I have a Salamander whole house pump which packed up today. I had a look and the inlet filters were partially blocked, so I've cleared them. The pump now seems to be almost working,
but....
the pressure form the taps seems lower and it's cutting out after a few seconds.
1. Could it be an airlock?
2. If so - any suggestions on how to clear it?
DIsconnet pipes from inputs. Water should flow freely. If airlock possible, connect mains to shove it back up the pipe.
Not common for it to be that though. These pumps are rather fragile - if the input flow is restricted for any reason they get hot, bothered and bust.
If the plumbing isn't as per manual, or HW is over about 60, put it right.
Thanks Chris
The pump seems to be running as before now, but with much less pressure. I think it must be damaged in someway, because the flow from the tapss is nowhere near as strong as previously.
I think i'll have to speak to Salamander on Monday. Probably end up buying a new pump. Any suggestions.
Its possible the seals have overheated and causing too much friction.
