Sand or SLC under PIR on slab
17 Apr 2015
Got a slab which I’m putting DPM and PIR and chipboard on top of. The slab dips in one corner by about 10mm, reckon I’ll get away with some sand under the celotex to level it or do I need SLC? There’s also another DPM under the slab.
Sand won't go anywhere. If you are worried that it may, mix a bit of cement with it.
You may have some sand (and cement) knocking around, if so you don't need to buy any self leveling.
Excellent thanks. Sounds like a plan
