Sanding kitchen oak worktop
15 Dec 2008
London
Hi
I normally wipe some Danish oil over my oak worktop a couple of times a year.
It's got a few stains where it's been in contact with stuff that has been absorbed and won't wipe off.
Should I sand it before oiling it this time? Will that be effective at removing the stains?
What grade of sandpaper should I use? Should I start at 180 and finish with 240 before oiling?
Should I use a machine sander or do it by hand?
I've attached a photo - cheers for any help.
View media item 86055
Water marks are caused by trapped water, a hot iron over tissue will steam them out of the surface.
I'll give that a try.
I'm not sure the orange marks are caused by water though.
I think your sandpaper will clog with the oil residue long before you make much progress. Might be better considering steel wool and turps substitute, rinsing the wool in the turps periodically. Work with the grain, not across, or you'll end up with a right mess.
If you don't want to use steel wool then use wet&dry paper again with turps subs. 180/240 sounds a bit coarse, you might want to try something finer first to see how it goes.
If you do go with sandpaper, avoid that green stuff that the likes of B&Q sell. The dye comes out onto the work.
