sauna
21 May 2006
wiring a sauna 26 m away from the mains.do i need to put an isolator next to the sauna supply (a control panel) or can i come straight from the mcb. do i need an r c d
Simon,
If the control panel has it's own isolator ie door interlocked/master on off that isolates the supply then no, if not then you need one. As for the RCD what does the manufacture recommend?
I presume it is powering a heating element to produce the steam so it will need a local D.P. isolator. (see BS7671 regulation 554-05-03)
RF did you have that regulation tucked away in the back of your mind ? :shock:
I'm note sure if we are talking about the control or the heater. If the heater is wired directly into the control panel as a package and the control panel has it's own DP isolator and DP controls I would have thought that would meet 554-05-03?
I've not got a copy of the regs to hand so I'm going by memory which is not always up to scratch
If the controller has an integral DP isolator then it is unnessecary to fit an additional isolator. I have only ever fitted one controller for a steam room so I am no expert, but the one I fitted was a glorified shower with no built in isolator.
Not sure if a RCD is actually required but it would be a good idea if there isn't one already.
If fitting a seperate RCD anyway then you could use it as the local isolating switch (provided its located outside the steamroom) and kill two birds with one stone.
It was the use of the words "control panel" in the OP that lead me to believe that this one could be more than glorified shower but who knows.
