- Joined
- 2 Nov 2016
- Messages
- 3
- Reaction score
- 0
- Country
Hi Everyone...
I've spent a good chunk of the day searching the forum but haven't come up with this one.
I've just moved house and the property has an existing and very dated scantronic 9448 panel (I don't think its the plus variant) which hopefully I'll swap out for perhaps a G4 or similar.
But in the meantime hope to continue using this....however I can't make it set. In 'day' mode no zone lights lit only power and day....all seems ok. When setting the panic LED is lit whilst it goes through its chiming/setting timer the system doesn't set and begins to alarm. I've found numerous links to instructions etc but non specifically say if the panic light should be lit or not through setting. They only mention that a zone or panic light would be lit after activation. The panic button seems visually to be ok not that I have a reset key if it were active. But just wondered if anyone could remember if the panic light should illuminate through setting and if I therefore need to be looking elsewhere for an issue.
As an aside, not sure if it assists but I tried to put the panel into walk test as per the manual , '5' then enter then setting code. Nothing happens other than going into what appears to be the normal setting sequence.
Many thanks in advance...
Dave
Dave
