Scantronic keypad replacement
6 Nov 2008
I have a Scantoronic 9800 keypad which has seen better days. Is it possible to replace just the keypad and if so which one would i need to buy
Exactly the same as you have, keypads are not interchangeable between different control panels - eBay (if you are lucky)
much cheaper as you can still get the 9800 plus keypads at a whopping £130 plus vat ..... they only use to be £35 lol....
even better go on ebay type in scantronic 9827 theres a cheap one and a even more expensive one.....
Not only are they expensive, they're hard to get, too. Scantronic build them in small batches, from time to time...
Strip it down and clean the PCB where the keys press with a rubber (eraser) and then wipe the black rubber "pills" on the back of the keys about 20cm/8" across a piece of rough card, like the inside of a cereal packet. Blow it clean and reassemble.
If you've got the black-faced keypad with the flap that hinges (used to hinge!) at the bottom, disassembly is a bit tricky. You have to slacken all the screw 'terminals' and, after removing the screws that secure the PCB, gently prise the board up from the bottom edge.
