- Joined
- 10 Apr 2022
- Messages
- 3
- Reaction score
- 1
- Country
Volkswagen Scirocco
1.4L TSI
2010
109k miles
Hi all, last time I received some great advice so hoping to get help here before going back to another mechanic.
Since November last year I suddenly noticed a drop in power when in 5th and 6th gear. The revs would be between 3000 and 4000 going at 80mph+ but suddenly it would feel like Iv lost all power and the revs would drop slightly but then climb up to almost 5000 with foot to the floor and going max 70 and struggles on any elevation. I would need to downshift but struggle to get the power again. This seems to be happening once im on a motorway for more than 10 minutes or so. This never happened before and now happens almost every time.
I presumed it was a slipping clutch and a mechanic agreed but after he did some other work on my car, it turns out he’s a cowboy so I don’t trust his opinion as he is only after money. I brought it to another mechanic I know when visiting Ireland who took it out for a spin and said the clutch is fine and is most likely spark plugs or the coil. He connected to the cars computer which flagged coil 3 and said there was raw fuel going in. This was during a trip home to Ireland so I’m back in the UK and can’t go to him.
I replaced the plugs and the coil that flagged as failing on his system but the issue is still there.
I’m still thinking clutch is the issue but hoping it’s something cheaper. My last trip to the mechanic for a service ended up costing 1300 quid so I’m a little hesitant to go with an unknown issue.
These are also happening so not sure if related:
Engine light has come on
Car shudders occasionally in neutral when electrics are on
Revs sit below 1000 in neutral
Clutch pedal feels normal
1st gear sometimes sticks
If there’s something I might be able to try before spending 1k on a clutch it would be greatly appreciated and thanks again if you made it this far!
1.4L TSI
2010
109k miles
