Screenprinting table arm
5 May 2008
Essex
I have a screenprinting vacuum table but it has no arm. The basically has a steel pole on the pack with a bracket attached with bearings that slide along the pole. Now the steel pole i have is too thick to fit the bearing bracket and the bracket is not adjustable. So is it possible to either thin the pole to fit the bracket or bore out the bracket to fit the pole? The bearings are removable. It looks to be steel and the pole seems to be hollow but no idea how thick.
