    Dismiss Notice
Screw through gas pipe
Discussion in 'DIY Disasters' started by ort67, 20 Jun 2018.
  1. ort67
    ort67
    11 Dec 2015
    85
    Thanks Received:
    3
    Country:
    Not DIY but I thought I'd share it anyway.
    Got home to find a Gas Emergency worker frantically checking the stairwell in my block of flats for a leak of gas as someone had reported a strong smell of gas.
    That afternoon workers had been installing fibre optic cabling and secured a wooden panel back on the wall that screw that was too long resulting in the screw going right through the gas main as shown in the photo below.
    Luckily the Gas Emergency worker found it before the it reached an ignition source. Could have been a disaster.
    • Like Like x 1
  2. blup
    blup
    5 Nov 2007
    1,004
    Thanks Received:
    144
    Country:
    Why not let your landlord know and inform fire and rescue, I'm willing to bet they will interested in the fire safety implications.
    Blup
    • Thanks Thanks x 1
  3. Ian H
    Ian H
    14 Sep 2010
    6,186
    Thanks Received:
    680
    Rochdale
    Country:
    After they fix it stick one of these on it :)
    • Like Like x 3
    • Thanks Thanks x 1
  4. conny
    conny
    30 Jun 2008
    11,235
    Thanks Received:
    341
    Suffolk
    Country:
    Many years ago I was helping my ex father in law to relay some floor boards after we had been doing some work in his house.
    Some of the short boards had 3 screw holes each end so we went round putting screws in the outer edges. Comes to the last board and we had 2 screws left. Yep, he decides to put one in each end through the centre hole. He got one in but was struggling to get the other one in so asked me to tap it with a hammer and give it a go. Light tap with a hammer and it screws in with ease. Sitting back having a cuppa and a fag and we both realise we can smell gas. Suddenly we are both down on our hands and knees sniffing to find the leak, not realising we are still smoking! Found the leak by hearing the hissing and yes it was the screw I had put in for him. THEN we remembered we were smoking! LOL. Rushed out the room to put the fags out and also turn the gas off at the mains. He repaired it by pushing a small clout nail into the hole, (the screw had only penetrated through the top of the pipe), then sweated a big lump of solder over the pipe and nail. It was still there more than 30 years later when he sold up and had had the pressure tested a number of times over the years.
    • Like Like x 2
  5. cdbe
    cdbe
    22 Nov 2009
    582
    Thanks Received:
    79
    Oldham
    Country:
    Many years ago I plumbed my new washing machine with one of those self cutting taps that clamp round the copper pipe under the worktop and screws in:
    I was feeling quite pleased with myself until I couldn't get the washing machine going. It was only when I started to smell gas that I realized the error of my ways!!!
    • Like Like x 15
  6. john4703
    john4703
    29 Sep 2009
    374
    Thanks Received:
    24
    Glasgow
    Country:
    A memory of mine from many years ago is fitting a gas fire for a friend, tight budget so we had bought exactly what we needed. He put a nail through the new copper pipe.
    We turned off the gas, undid that section and he sat on the floor with his finger over the end of the pipe while I used the gas cooker to heat up the damaged section and soldered the hole closed, he and his family lived in that flat for many years with no leaks.
  7. Keithmac
    Keithmac
    10 Oct 2017
    1,350
    Thanks Received:
    216
    Country:
    Quality!.
  8. JBR
    JBR
    9 Jan 2007
    8,798
    Thanks Received:
    382
    Cheshire
    Country:
    Excellent! That's one of the funniest things I've seen on here for some time! :LOL:
    • Like Like x 2
  9. Sponsored Links
  10. Robbox
    Robbox
    21 Jul 2010
    434
    Thanks Received:
    3
    Weymouth, Dorset
    Country:
    Even more years ago, my brother was studying at the local art school and mentioned he could smell gas, so he got out his lighter to have look.....
    • Like Like x 1
  11. FiremanT
    FiremanT
    16 Jan 2012
    7,912
    Thanks Received:
    1,484
    Uk
    Country:
    First timeI have looked in here.
    "Bodger twats R Us" springs to mind. And so proud.
    • Like Like x 1
  12. dave163
    dave163
    25 May 2012
    50
    Thanks Received:
    Wolverhampton
    Country:
    Many moons back I was living in a semidetached 1920s house. Came back one evening to an overwhelmingly strong smell of gas upstairs in the landing (fortunately detected before turning on the lights!) Opened all the windows, called the gas board. Engineer comes out, gets all the floorboards up, can't find any leak but advises us to sleep with windows open and not turn on any lights until he returns in the morning.
    Next day, same thing. Overwhelming smell of gas, engineer comes out, floorboards up (again), no trace of a leak.
    After a while he has a brainwave. "Are your neighbours in?"
    Pops next door. Slightly embarrassed neighbour fesses up that he was doing some DIY the previous day and drove a nail through one of his gas pipes. He turned the gas off at his main tap overnight but turned it back on again in the morning to cook his breakfast and was planning to nip out later in the day to pick up a new bit of pipe but hadn't yet got around to doing so.
    • Like Like x 3
  13. bernardgreen
    bernardgreen
    3 Nov 2006
    22,420
    Thanks Received:
    2,104
    Bedfordshire
    Country:
    • Like Like x 2
  14. Mottie
    Mottie
    27 Feb 2017
    5,454
    Thanks Received:
    644
    Essexshire
    Country:
    Many years ago a not particularly bright friend of mine smelt gas near his meter so he called in the Gas board. According to him, the engineer found a rubber washer on the floor near the meter that had fallen out when he was spinning his gas meter round to make it run backwards.
  15. rds60h
    rds60h
    5 Mar 2015
    27
    Thanks Received:
    3
    Bedfordshire
    Country:
    This reminds me of the time my brother who was a tool-maker decided to play a trick on his foreman; he got a tobacco tin, cut a hole in the bottom large enough to put his finger through then lined the tin (and around his finger) with cotton wool and squirted tomato sauce around the area where his finger was then loosely put the lid back on. He then went up to his foreman and said "I'm afraid I've had a little accident" and then took the lid off the tin to show the foreman................the foreman promptly passed out, which was not exactly the reaction he wanted but it gave a few other workers that were round about a good laugh.
    • Like Like x 2
    • Thanks Thanks x 1
  16. ericmark
    ericmark
    27 Jan 2008
    14,972
    Thanks Received:
    1,337
    Llanfair Caereinion, Nr Welshpool
    Country:
    Not gas but water, I screwed floor boards down (dad's house) and a screw when through the central heating pipe, it was 3 months before it started to leak, and of course one screw out water everywhere. Since only central heating finger stopped leak, but then needed to get some one to turn off water to drain system before I could solder up the hole. Could not believe it lasted so long, second central heating leak my house fitted all central heating been running for at least 2 years, and then a bit of flux came off and water leak, just when last child was born and was flying to Algeria next day, lucky it was not a day latter of house would have been flooded.
Loading...
Share This Page
