I've just finished sheeting a stud frame partition and I'm about to cover the joins with scrim tape. My question is, do I apply it to the joins where the partition meets the existing wall and ceiling?
Short answer is yes.
Corner tape going around the corner.
I mostly didn't though.
I made sure there was no movement.
I would use a polymer grab like CT1 along joint then put a tape down tight to wall Vs going around the corner.
The tape just covered the gap and filler
What's the construction of the existing wall? Are you going to redecorate both?
I have taped corners like that (and ceiling joins). Same as corner in new plasterboard; apply compound, bed paper tape into compound, more compound over etc.
