sealing concreate garage floor
13 Feb 2006
West Lothian
i would like to paint the garage floor and seal it to stop the dust gathering.
how do i go about and do this project please. Simple instruction breaking it down into small steps would be fine.
thanking you in advance.
Be warned that painted floors are extremely slippery when wet unless you add a traction grit to your floor paint.
For best results, I'd look under "Coatings" in your phone directory and go talk to the salesmen working for the companies in your area that do concrete factory and warehouse floors in epoxy or moisture cure polyurethane. They would be the most knowledgeable people you can find about applying a durable coating over a concrete floor.
So, even if you get lots of advice in here, I'd still talk to the salesmen working for companies that do this kind of work frequently, cuz they're the ones that know what problems you can run into and how to best overcome them.
If you want a good cheap solution ad your not to fussed about the appearence....give the floor a coat of PVA diluted by the manufacturers instructions...its quick drying and the cheapest solution...youl need to do it once a year though
If the look is more important then go for a floor paint...take note of the preparation instructions though...concrete can be a bit troublesome to paint..again an easy option using floor paint will be to thin it down a fair bit first...it should soak in quite a bit still leaving you with some traction/non slip qualities.
