Sealing cut edges
8 Dec 2008
Kent
Whats the best thing to use for sealing the exposed ends after cutting down worktop and the 18mm end and back panels to stop moisture getting them? Is it still neccessary although I will stick edging strips on after cutting? :)
A few coats of [clear] varnish.
Edging strip alone wont be sufficient if the edge might get frequently wet (eg cut outs and joints) but might be OK for edges and panels
