I'm in the middle of fitting out one of my walls (almost end to end, top to bottom) with IKE Plasta cupboards and have come into a bit of an issue in the first column of cupboards.
My house is a Victorian terraced house and the render/plaster on the walls is very crumbly (and maybe even the brick - I don't know). I have IKEA Platsa cupboards going up about 2.5m high from the ground and I need to attach then securely as I have kids. They're floor standing but I'm worried about toppling from kids climbing.
Each unit has 2 fixings on the top corners. The problem I've had is that sometimes the exact part of the wall that aligns to the securing point is crumbly and the screw and plug just spin out. I've tried various tricks like putting a red plug inside a brown plug, using matchsticks, etc., but the hole sometimes still crumbles away pretty much leaving a crater so I'm left with only securing that cupboard on one side which I'm not comfortable with. On top of that, I've had to take the cupboards off a couple of times and probably will have to again to do some wiring behind for lighting and the screws and plugs naturally loose tightness and strength from this.
Here's the workaround I've thought of:
Get some sheets of half inch ply and secure a 3 foot section across the top of the wall behind where the cupboards are secured to the wall. Use two rows of solid screws or even wall anchors at about 50-70cm intervals to ensure the sheets are well secured to the wall. Then, I would use threaded inserts and M6 bolts to attach cabinets to the plywood. That way I can take them off and put them back as many times as I want and my gut feeling is that the net holding strength will be greater than if I just attached cupboards straight to wall. If I hit a bad spot with when securing the plywood, I can just move along or double up.
What do you think of that and do you have any alternative suggestions?
Thanks in advance for everyone's thoughts.
P.S. These are floor standing so it's only to mitigate topple hazard but I'm planning some wall hanging ones on opposite wall so any comments on using the same strategy there will be equally appreciated.
