Securitech ST800L Keypad Relocation
21 Aug 2013
Birmingham
Hi all, hope your all having a good day!
Need some advice on my ST800L system.
We're having some home decorating done and I'm looking to move the alarm keypad to a new location. I'm a electronics engineer so feel competent enough to have a go do it myself, my only reservation is if i trigger the alarm off in two external bell boxes, how would I switch it off??
Any tips on making the alarm safe whilst I move it welcomed. I have some 6 core cable for the refit at hand. Thanks
21 Aug 2013
Birmingham
Thanks sparky. How do I get into the eng mode? Is it the code begining with 7 :)
Also in this mode, if i open the main box, it won't trigger the alarm right?
Lastly, what's the process to dismantle the keypad from the wall without marking it.
Thanks again.
16 Feb 2011
Sheffield
Yes if it’s default ....it will make a noise until you open the box lid
Look if it’s got a small screw on the right hand side ...if not you will see a small slot ...CAREFULLY insert a small flat screwdriver DO NOT force it or the keypad will be no good ...it should pop out
