Got to put up some outside security lights at the factory where i do some maintenance. Im fine with circuit design, volt drop, ccc ect, but am just after some advice as to the best fittings to use as ive never put any up before.
the lights will be mounted 20ft up and im after the photocell type, what lights do others use i.e son, halogen, halide? in what circumstances are each best? also im thinking 400 watts are going to light the area up nicelly but how good are the 70's or 150's? what do others use in this factory type setup for outside security lights.
also ive come across a situation what i havent previously, there is a ring circuit available to spur one of the lights from. this would take the form of a fused spur from the socket with a bs1362 fuse protecting the light. the total run to the light would take the zs over the maximum for the 32A bs88 fuse protecting the ring but not (i would imagine) over the max for a 3 amp 1362. but to me the whole ring and spur to light would only seem one circuit, cant make my mind up whether the 1362 allows for the ''high'' zs on the ''one'' circuit.
thanks for any advice.
