Sentinel x100 and sealed heating systems
12 Dec 2007
Lincolnshire
Got a sealed heating system and i've attempted to inject some sentinel x100 into the top of a rad exactly how i was told by the merchant and the instructions on the tube and yes its ended up everywhere but in the radiator, surely there's a better method than this ? There are no towel radiators either in the system
18 May 2004
depends where i get sent
1 close both valves
2 open bleed screw to release pressure
3 screw cartridge into rad
4 open 1 valve pump into system
5 close valve
release pressure on the gun slowly
6 remove gun replace screw
7 open valves again
shouldnt lose much or make a mess :idea:
if you want to be double sure reduce system pressure before you start to app 1/4 bar
and repressurise afterwards ;)
18 Nov 2007
Lincolnshire
If you had got the fernox inhibitor tube for skelton gun then it comes with an attachment for filling loops. Much easier and less messy
7 Aug 2008
Farndon
I have found that it helps to release some pressure from the system before injecting the chemical, when I didn't release pressure it splattered everywhere when I removed it from the bleed point.
