Hi
I am after some advice please. I live in a flat that has a fuse box that has three fuses only. One for lights One for Sockets and one for Cooker. In the Kitchen there is the normal cooker wall socket with switch and 3 point plug socket and lower down is the plate for hard wiring the appliance. My wife recently purchased a separate electric oven and hob and I do not know the best way to install them. The Hob is an AEG HK95507FB it states it requires a electrical connection of 7.9kw and a fuse of 40 amps. The Oven is a Hotpoint DH53KS double electric oven and states it requires a electrical connection of 4.8kw and a fuse of 32 amps. If I have a fuse of 40/45 amps can I hard wire them both into the same socket or should I create a fused spur for the oven? or neither and need something else? Sorry for the long winded post but I wanted to provide as much info as possible. Also I believe the flat was built/renovated in 1980 in case that has some bearing on the wiring.
Thanks in advance for any advice given
