Hi All,
I currently have a radial circuit with 6mm cable & a 32amp mcb. I need to run a separate oven (3kw) & hob (6,270w). Not sure if i need a new mcb with higher rating or 10mm cable or both.
I understand i will need double pole isolation switch. Then a fused spur off the cable to run the oven. Then the hob will run from the cooker control unit further along the cable.
Please Advise, Thanks in advance.
CL
CL
