Hi all,
My septic tank soak away has come to the end of its useful life according to a drainage survey and requires replacement. I have been searching around on the internet for advice on how best to construct a new one but have come up against a lot of conflicting information. My property and the septic tank along with the soak away were constructed in 1967 so does not appear to be covered by most of the regs I can find which relate to new septic tank soak aways. The present soak away is a pit that is filled with rubble,we already have environmental agency approval for discharge to ground for this, but has become silted up over the years and subsequently blocked. My question is what can I use to replace this soak away, can I use the plastic crates with membrane and stone, some companies say this is fine as it is over 15 years old but others state that it must be a drainage field constructed from rigid slotted pipe in a loop with stone and a membrane. Any help on clearing this up would be greatly appreciated.
Thanks in advance Paul.
