Hi guys im building a side extension and knocking through the kitchen wall. i need to install the steels with the wall in place still. The property has been extented to the rear before so that steel is going to sit in the eye of the new beam were fitting.
The joists will sit on top of the new steel installed.
i want to know if i can set strong boys up between the joists picking up bothe walls and and acrow the joists up with a scaffold board.
All this from the inside so it means i can install the steels from the outside leaving the wall in. The cavity is 50mm wide
I hope this makes sense.
The outer leaf wall is taking the weight of the roof inner leaf is the floor joist. Thanks in advance i know ideally i would just acrow both sides but i dont think there would be enought room between the prop and wall to be able fit the steel in to lift up.
The opening is 4m .
The opening is 4m .
