shallow bath waste washer
15 Apr 2018
Well I bloody cursed it by saying my last post would be my last post.
Just in the process of finally fitting the bath in to seal it and I realised I couldnt find the washer that goes between the bath outlet and the shallow waste
the part number ht03-10 in the diagram.
I thought I had found a replacement washer from the old pillar tap (well it fitted) but no such luck.
Took the waste apart and rushed to screwfix- bugger its Saturday, closed!!!
So last hour I have been trying to find one.
The sizes make no sense at all to me as some are in mm and others are in inches - which I get.
But when I search for 1 1/2 sealing washers I get washers with 71 outer diameter.
The fitting I have (see photo) has 1 3/4" threaded nut, outer diameter of 44 (poss 45mm) and inner diameter of27mm and a thickness of 8mm
I have searched and searched yet cant seem to find the exact thing that matches,
I found this one:
but that doesnt give me the inner dimension
and also this one
But thought that is not wide enough.
The only thing I can see that actually measures correctly is
Would these work?
Or what do I need that I can buy tomorrow
I am already in big trouble as the bath was due to be sealed tonight for Mrs S coming home tomorrow night!
Thanks in advance
You need a trap inlet washer.38mm i think.Measure inside that nut and see.
the inside of the nut (the outside of the metal flange) is 44mm
Sorry that sounded rude, should the washer not align with the threaded pipe coming from the pipe (so it crushes against it)? or should it sit within the pipe?
It sits inside the nut and pushes tight against the bath waste when you tighten.
Thanks for that.
Silly question, but I seem to remember the washer being more of a flat washer. Is there a difference (I am sure there is) and does it matter so long as it seals?
