Client is getting shocks from the tap and shower scrren in the bathroom. I have measured (using a Fluke) approximately 10 volts ac. Previously, while attempting to bond the hot and cold pipes to electrical earth, electrical flow (presumeably from the switch plaster (metal) box) tripped the 6amp mcb as well as the elcb mains isolator.
Today, I was going to isolate lighting circuits from each other in order to locate cable that is causing the wall, around the bathroom light switch (located in the hall) to be live along with shower screen and the bathtub/ taps. Access to underfloor is not (at present) available but am working on it.
Views from reqular knowledgeable would be most appreciated.
