My first post.
We recently bought a huge Edwardian semi and have the luxury of not living there while we carry out some work. We've had a complete re-wire and quite an extensive replumb and have stripped layers and layers of textured paper off walls and ceilings. Ceilings seem to be soundly affixed to lathes but some show have cracks up to 5mm which I intend to fill and sand.
Walls are a mess of filling, patching, holes and small (thankfully) areas of blown plaster which are a good enough size to make me think I can bring them up level with the surrounding plaster with an undercoat (though I don't know whether I should be using hardwall, or bonding on brick - any suggestions gratefully received).
My real question concerns finishing the walls prior to painting. Ideally I would like to have a complete reskim but it will cost a fortune to call someone in (4 beds, very large hall and staircase, 3 receps). I loathe the idea of lining which in any event I've never done so would need to call someone in to do that as well.
Is it possible to learn to skim on a 1-2 day course. Walls will have been filled and put into a fairly good condition. All walls are flat (no curves). There are interior and exterior corners with the odd 45 degree turn into bays. Over the years I've managed to teach myself most of the diy stuff I do but I don't have the confidence to have a go at skimming without a course. Is it possible to learn to skim properly, quickly, or am I deluded??! If anyone thinks I'm not mad, can you recommend any courses? Many thanks.
