    Dismiss Notice
Should you tank masonry wall?
Discussion in 'Tiling' started by veedee, 5 May 2020.
  1. veedee
    veedee
    27 Sep 2011
    460
    Thanks Received:
    13
    Country:
    Bathroom will have a bath with an incorporated shower
    Some of the wall in the bath/shower area is plasterboard.
    However the majority is breeze block which has been plastered over
    Does the masonry area need to be tanked prior to tiling?
  2. no. providing you use the correct adhesive and grout. pref not the ready mixed junk from B&q .
    • Thanks Thanks x 1
  3. Sponsored Links
  4. veedee
    veedee
    27 Sep 2011
    460
    Thanks Received:
    13
    Country:
    Okay, we'll tank the plasterboard area
    I'm using grout and rapid set flexible adhesive from mapei
    Tanking kit is from mapei too
  5. rapid set really is rapid set this time of year, bear that in mind when your mixing .....small amounts(y)
  6. Sponsored Links
  7. bobasd
    bobasd
    2 Dec 2017
    2,368
    Thanks Received:
    435
    Country:
    Dont use any kind of plasterboard on wet walls - if you have p/b on wet walls then remove the p/board and replace with backerboard.
    Tanking is not necessary but it would pay you to post a couple of pics showing the condition of the masonry wall surfaces?
  8. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
